Hi ! I have a GO720, and the touch screen doesn?t work properly.
When i touch in the top part of screen, is like touch the bottom part of screen.
And I can?t use the icons in the top part of screen.
Any Idea what?s happen ?? Thanks
Any help to get this issue resolved will be great. It is annoying to be without a GPS
Have you tried cleaning around the bezel? Also, do you have a screen protector? Over time, they tend to dry out, causing additional pressure on the glass, resulting in weird results such as you describe.
Then in Windows Explorer, click on 'My Computer' link and you should see the TomTom unit as a removable drive. Right click and one menu option is format. Don't select quickformat. You want to format as fat32 if given that option.
Thanks.
I've tried the touch screen calibration file, with various numbers.... No luck. Thanks in any case.
Need to buy a new unit since I use it a lot for work. Not sure I am going to spend more money on a TT model...
