OK... So, it appears that TomTom were a bit unlucky with the chip / leap year problem causing the GPS issue last week. Having that happen at the same time as the fire in the Vodaphone centre causing all Live services to fail was doubly unlucky.
However, having pushed through all that and come out the other side, something else has gone wrong which started with the update about 10 days ago.
The software on my Go Live 1005 doesn't appear to recognise the battery any more. It will only function at all when connected to either the computer or the car's power supply. As soon as you disconnect the power lead, it shuts down with the 'low battery' screen yet, immediately before doing that, you can check the battery status in 'settings' and have it showing 90% or 95%... It's as if either the battery won't charge any more OR that the software won't recognise that the battery is actually charged.
There was no such problem before the recen software upgrade about 10 days ago which co-incided with the start of the other recent problems and the unit is only 14 months old (purchased in Feb 2011). So it's out of warranty if the battery has failed, but I'll be damned if I'm paying €105 for an out of warranty repair on a top of the range £200 (odd) sat nav that's only just a year old. A rechargable battery on such a product should last longer than a year.
Luckly, in the UK, we have The Sale of Goods Act 1977, which gives consumer protection beyond the manufacturers warranty period IF the goods were faulty at the time of purchase. It could reasonably be argued that a £200 sat nav battery should last longer than 14 months and that would allow a claim against the retailer (Halfords, in this case). I would actually hope though, that TomTom themselves would offer some kind of goodwill repair and accept that they should be doing better themeselves.
All assuming that there isn't still a software fault causing this little problem, of course.
Anyone else suffering from such a problem? (no point in phoning TomTom support at the moment as they appear, rather unsurprisingly, to be swamped with callers who cannot get a GPS signal and/or 3G signal.
I know TomTom have been a bit unlucky here but on the back of having to phone TomTom support about 1 in 3 times I do some sort of upgrade anyway, it doesn't look good for them.
Can anyone offer me some good news?
