Hello gang! I just recently bought GO 930 and USB antenna for it. I am not happy with the way usb charger plugs into antenna dongle and then into USB port on 930. I was wondering if Serial antenna can be used with GO 930? thanks
You can use either of the RDS-TMC devices with the 930, I find the mini USB is slightly better at grabbing a signal, but the round type unit is a better solution as it doesn't lose everything when you turn the ignition off, it can then take ages to re-acquire a signal depending upon where you are.
To get around the reception issues and the fact I decided not have wires all over my car I elected to bury the whole lot and connected the RDS receiver aeial to my car aerial, this offers a neater apperance (no wires) and much better performance in areas of marginal reception - Mike
