Hi All
I recently updated my GO730 maps to 8.35, but since doing so I no longer get markers (icons or sounds) for UK safety cameras. The option isn't in the POI's list on the device either.
When I open the device to windows explorer I can see the following:
Safety_Cam_UK_TomTom.ov2
Safety_Cam_UK_TomTom.ov2.dct
Safety_Cam_UK_TomTom.ov2.ver
When on the older map the cameras worked fine, and when I replaced the map files back on to the device they worked again .... yet with the new map (and only copying the map files over) the cameras don't appear.
Any help would be appreciated
Regards
John
Regards
John
