GO 730 - Help!
Chesterville, ON, Canada
Go 730
Ok so I got a GO 730 for Christmas and started to play.....big mistake. I'm a newbie to TomTom's and did not do a back up prior to starting. I know now this was a huge mistake!:mad: Anyways we used it in the car and noticed a few roads didn't come up that have existed for 30+ years. I thought that was odd so I loaded up the latest version of home and did an update.
I didn't have any SD card installed at this time. Again bad idea. It wiped out the original map the unit came with and didn't complete the download. Thus began the "no maps found" msgs. I began to read and tried out a few things based on "tomtom support" solutions. No luck. Things started to go from bad to worse. I began to get "runtime errors" when I would open the home program. Not sure why??? Does this happen when you open home and turn on the unit out of sequence, as that seems to be a very important step? Anyways I've now downgraded my home program to version 2.2 instead of the latest and greatest and no longer get any runtime errors.
So my next big issue is loading a map. I purchased a 2GB SD card yesterday and installed it. Opened up home selected to put the new downloads onto that drive (H:\ in this case) instead of the internal units drive (G:\) and did an update. It loaded some new voices etc and the map (New N/A map, not postitive on the version but it's the latest one via Map Guarrantee) but when it finished a msg popped up saying there wasn't enough room for the map file it requires me to erase 1.2 GB from my unit. :mad: I looked at the files sizes prior to downloading and they should have fit on the card with room to spare. What am I doing wrong and how do I get out of this mess??? I'm trying to avoid exchanging the unit since it was my mistake but I seem to be banging my head on a wall here talking to their tech support and trying to get a map back on the unit.
Step by step help would great. I can get much more detailed info if needed. I cannot get my firmware version however since the unit will not boot past the "no maps found" sequence.
Thanks.
Ok so I got a GO 730 for Christmas and started to play.....big mistake. I'm a newbie to TomTom's and did not do a back up prior to starting. I know now this was a huge mistake!:mad: Anyways we used it in the car and noticed a few roads didn't come up that have existed for 30+ years. I thought that was odd so I loaded up the latest version of home and did an update. I didn't have any SD card installed at this time. Again bad idea. It wiped out the original map the unit came with and didn't complete the download. Thus began the "no maps found" msgs.
We all make mistakes. I wish TT would put a warning on every unit to make a backup the very first time you power it up.
I've tried it every way imaginable and have never had an issue with runtime errors. I don't know what platform or OS you're running so I can't help you there.
That's a good thing. :) At least you're up and running there.
I'd get at least a 4gb card and try and load everything on it. But to begin with go to windows explorer and delete everything off the SD card you have then open home and do an update and uncheck everything but the map. Download that to the SD card and roboot the 730. If that works and you can select the map, open windows explorer and backup everything (both the SD card and the internal memory on the TT) then you can move everything to a larger SD card if you want. Be sure to make backups after every change. I keep my latest configuration in at least two places.
It's hard to say what went wrong especially with the first update but hopefully the above suggestions will get you on your way.
groundhog
