Go 730 and Blackberry 8310 AT&T Wireless data connection
NYC
Go 730
Does anyone know the manual set up? I've tried the loaded profile on the tom tom and is not working.
I have seen the setting for both TMo and AT&T in this forum in past years, I would do a search of some key words and I am sure you will pull it up pretty easily.
Note - you may only have to change the access address to get it to work ok - AT&T may have changed it (they are trying to cut back on data service access across the board). If so, you may have to scan AT&T wireless data forums for the most recent settings.
I have read the other posts, very few with successful connections, this post was my last resort since I tried everything they recommend.
I will look at AT&T wireless forums.
Thanks.
Peter2471
