GO 630 display problem
central Florida
630 GO
2 year old GO 630. Working OK until last week when I turned it on and the screen has a darker center spreading out to the corners. No moisture indicated in the display, just a darker center that 's difficult to see in sunlight / outdoors. I use it in the car and on a pontoon boat for positioning and speed display. Problems with moisture in unit??
It may be.........
Try this (serious).......
Imbed the unit in a bowl of UNcooked rice for 24 - 48 hours. See if that helps.
