Hi,
Three problems.
Updates at home (fast fibre broadband) are VERY slow, the first 75% is fast, then go and make ten coffees and it may be at 80% then it eventually (30 minutes or ten coffees whichever is faster) switches to the actual update (previous part was just the download?) which is done in minutes.
Various TomTom web pages suggest that "MyDrive" should be in the 6200 under Settings? It isn't to be found. Some account info is under Settings "TomTom Account " or WiFi
I have TomTom "Home" and "MyDrive" installed on my PC. MyDrive connects via USB, "Home does not"
I can live with the SLOWWW WiFi update, except in emergencies where speed is of the essence. The other problems are just totally confusing when you read TomTom web page instructions which then can't be used.
Regards...
Three problems.
Regards...
