Go 620 Won't power on
Go620
Hi all
I think I know the answer but worth a post before I replace it.
My Go 620 won't turn on. I've changed the charger lead and also tried charging from a different source (eg. car to computer)
but it's dead. I'm assuiming the battery has gone. I can;t find any reset buttons on it.
Does anyone have any suggestions?
Thanks in advance.
Karl
Hi
Press the power button until you hear the sound of the tom-tom and the device restarts.
The best thing is to charge your GPS on your phone's mains charger.
Hi all
Thanks in advance.
Karl
Open the tontom, disconnect the batterie from the mainboard, get power from the charger en press the powerbutton for 20 seconds. It Will start.
toerjoop
