Go 620 wifi problem software
<img src="/styles/default/custom/flags/es.png" alt="Spain" /> Spain
GO 620 wifi
Hello I have a tomtom GO620 and from Ace 4 or 5 days I update the software when you put it in 3d mode or to guide you on a route, it turns off only after 10 or 15 minutes and restarts without the route
s the battery fully charged and do you drive with the device connected to power via the included cable?
the gps is loaded and is connected to the power of the car with its corresponding support.
I have not had any problem until the software update
Perhaps chat support when open:
España (Spain)
913496508
Lunes-Viernes: 09:00-17:30
martinvans
