- Joined
- Aug 16, 2010
- Messages
- 5
- TomTom Model(s)
- GO 520
My GO 520 is about 21 months old and has a continuing battery issue. Approx.10 months ago I returned it under guarantee as the battery was loosing its ability to hold the charge and was only good for about 2 hours at best. When new It would last a maximum of 3 hours, even though I read some where it should last up to 5 hours. I appreciate it depends on how many facilities are switched on, but I only run the bear minimum. They returned it saying a new battery had been fitted, but it was no better and the battery will now drain in less than an hour and is getting worse. The battery appears to charge normally but the green bar never quite makes it to the other side. In short, its only good for use in the car when permanently connected to the charger.
I have read how some people have fitted a new battery them selves and still not solved the problem. I have also read here and on other forums how poor battery life is a common problem with TomTom satnavs and wonder if anyone has any advice on tackling this issue.
