Fixed Car mount for Tomtom Go Exclusieve 7" (= Tomtom Go Navigator 7 )
Hello,
I bought the Tomtom Go Exclusive 7"in summer sale (in the Gui it says its the Tomtom Go Navigator 7) with the camper caravans route option. It works great but now I'm in search for a fixed car mount
I'm talking about a mount with a flat backplate that can be fixed with screws to the front of a dashboard or on a Brodit mounting kit
I had one in my old car car for an old and smaller tomtom.
I mean something like this: https://www.bol.com/nl/nl/p/tomtom-...HhovNZfixs-Zi-R0669hyJk-kxh8TYgIaAtK_EALw_wcB
But I think this one is for am ( older) 6" tomtom I guess.
I cannot find it in the tomtomshop and because I dont know if my new 7"navigator with USBc can fit on the one I found on above website, I hope you guys can help me out.
I had same trouble sourcing the correct parts but managed a set up on my brodit clip in my Ford Mondeo mk5 2016
I've found Brodit UK to be very helpful, isn't there a similar distributor in your country?
I had a brodit clip in my Mondeo for my Tom Tom 5200 ,basically I used part of that and took the one for the new Tom Tom exclusive off and screwed it onto that
I use a Brodit Clip exactly like that one with a Go Superior 7”
I also used another one of their mounts so that it can be easily removed allowing me to easily drop in my mobile phone.
Taity
