I didn't know about the sound level problem with GO devices until I have tried myself. I was about to return my latest GO 50S when I got a prompt to install "require" update that was about 350mb is size and noted something about fixing sound.
After an update, I can now hear the freaking directional voice. it's still not as loud as Start nor the XXL i have but at 100% it's loud enough to hear with window down. for those contemplating on returning your GO device, update your software using your MyDrive Connect and hear the difference before returning.
One thing missing in GO is that I can't no longer create my own start/shutdown images and "pointer" icon. I have always used my actual vehicle to customize the device. May be next software update? I also wish there is a way to reorganize the options to fit my needs because I have to shuffle to cancel current destination. I have GO 50S but after the support reset "something" because I had an issue with updating the map, it now show as GO 50 in MyDrive Connect but the operators see 50S in their screens. I have given up fixing the traffic option that suppose to come with 50S which is not available at the moment and two operators have given up already. Traffic is not a show stopper so I have decided to keep it as it is.
My latest GO is so much more improved. Tracking is so much faster with very little lag time and recalculation is also faster. I am also glad GO device restored the auto on/off like the "old" XL I had long ago. screen transition and motions are also smoother.
