Hi all,
I bought a TomTom XL in mid-2010, and ever since I started using it, even if I NEVER bought the TomTom Safety Cameras subscription, I could see at least some warnings of speed cameras, even if probably they were not the most complete nor the most updated ones.
Anyway, a few months ago something strange happened to my device when I was trying to change the Map Zone (I have the full Europe XL version), and all my config and favorites vanished from the device. Not so much harm done, I kept using it normally, but I realized that the speed cameras warnings had disappeared.
Since I'm not using the device so much anymore (I finally learned how to circulate around my new home in Europe), I didn't look deeper into this until today. I thought it was just a configuration option. So today I went to look at the Options menu, and found the "Enable Speed Cameras" option, but it is disabled (grey'd out)!
Anyone know why is that? How can I get back my speed cameras warnings, even if my map is quite old by now? I'm actually thinking of buying the 1 year map update now, but I wanted to fix this problem first.
Many thanks,
Leo.
PS: I don't know if this makes any difference, but I remember buying the TomTom XL2 device, which was a newer version of the TomTom XL. However, if I go to the "System Information" window in TomTom HOME, it says my device name is "TomTom XL".
Many thanks,
Leo.
