Direct Power Cable for 510?? Help!
Is there any cable on the market that I can plug directly into the 510 for power only? I want to mount this on my motorcycle. The mount is no problem, but the power adapter is built into the tom tom cradle!
I need a DC power cord to hook up directly to the unit
Thx!!
There is no cord that go directly to the unit. Everything connects to the mount.
However, you can dismantle the mount to remove the suction part of it like I did in my mod: here
Where is the cheapest place to get a extra mount?
I saw your thread and its perfect!
I wish someone made a cable! I found a hardwire cable to the DC input on the shoe, but a all on one would be grat
eBay is the probably the cheapest place to get a mount. But be careful as there are knock offs.
Good luck, let me know if you have any other questions.
