Destination input problem
G960
I have a new g960'and I can't seem to be able to input a destination using latitude and longitude which I could on my old device. Can anyone help?
I cannot tell what model a g960 is.
Are there any additional designations?
What do you use to connect to the PC HOME or MyDrive Connect?
It seems to be a Go960. I bought it because I could download free world wide maps. I am presently in Portugal where if I could use lat/ long to find our next port of call that would be terrific. I have downloaded the app onto my iPad but frankly find it pretty useless in helping with this problem. I have had an older model tom tom which gave me the option of using lat/long which was fantastic while overseas which is where the device is used but that one died in Croatia last year.
I've never heard of a GO 960, either but ... If it is a recent model, when you perform a "Search", there's an oblong bubble in the upper right area that probably says "Whole Map". Click on that and you'll see several options. The bottom one is for entry of coordinates.
Peter2471
