deleting a POI? Help
I am new to this. I have a POI that I cant seem to get rid of. Can some one plese help Some how I got a local pool called Skyline pool stuck on it and I am not sure how to delete it?
I think what you are seeing is just normal operating procedures for the software. I assume you're seeing an icon for the local pool. Well, as soon as you add a new poi, the new one replaces the previous (in this case, the pool) icon.
And so it goes ...
Yes, you are right. I figured it out as soon as I entered a new POI and looked again. Thanks, for repling.
