Connecting GO 5200 to My Drive
St Neots, UK
GO 5100 World
When I connect My GO 5200 to MY Drive I get a message saying that "I can update the 52-- the easy way - using wifi".
That is all - I cannot get the My Drive to move to any other page.
What am I doing wrong?
Nothing. That model normally uses WiFi and doesn't use MyDriveConnect at all. If WiFi is not present, you CAN do your updates (all updates are done on the unit) with the usb cable connected to the computer and MyDriveConnect running BUT minimized.
