- Joined
- Dec 26, 2008
- Messages
- 2
So I've had my TomTom GO 720 long enough to learn its little quirks and issues (especially with bluetooth!)but now it is completely dead and won't turn on at all. It's never been dropped or abused, pampered if anything.
I've tried the reset switch, as per the TT website troubleshooting instructions. Also, the computer doesn't know it's plugged into the USB dock..
The only ray of hope I see is the green power/charging led light comes on when plugged into the car charger or USB dock... otherwise it's a brick.
I did it's first system and map update about 2-3 weeks ago.. Had the GUAM issue I just noticed on here then it seemed fine since, even a little better overall maybe.. Until the other night.. came home, switched it off like normal, left it in place mounted in dash.. next morning go to head out and it won't turn on..
Anybody have any ideas, tips tricks or have you seen this before?
I made a hell of an investment on this thing and the custom car dash mount etc.. for it poop out like this.. I'm regretting not buying Best Buys replacement warranty..
