canderson
Moderator
- Joined
- Dec 28, 2007
- Messages
- 13,698
- Location
- Colorado, USA
- TomTom Model(s)
Coline - you cannot receive private messages, so I was unable to reply there to the message that you sent to me. You're not alone, however... I saw yet another message in this area that requested this information.
I've seen the lack of ability to charge an "old" one work out two ways -- a battery that won't charge even when the charger is making a valiant attempt, or a charger that doesn't start the charge because it can't even "see" the battery. Recharging one that is this low can be quite a trick, and the charger may even prevent it intentionally for safety reasons.
Depending upon the charging circuit in the ONE, it may be possible to jolt the poor thing into life by repeated attempts to charge it. If it is still possible to charge it at all, plug/unplug cycles of about 15 minutes over a period of several hours may cause it to develop enough charge so that the charger can complete the job. Worth a try, and much easier than your only other option -- a battery transplant.
FWIW, the transplant can be done for the price of a new battery (about $22 plus shipping) and about an hour of someone's time who's handy with such things.
Although my battery swapping tutorial was specific to the x20/x30/x40 series units, it may well serve for instructions to replace a ONE battery. Worth a look here:
https://www.tomtomforums.com/tomtom...730-920-930-battery-replacement-tutorial.html
The battery itself can be procured here ... I believe it's the F650010252 model:
TomTom ONE, ONE Europe, ONE Regional, RIDER, V2, V3 Battery
Lithium Ion batteries don't like to be discharged below a certain point, and leaving one sit for a VERY long time can cause that. A good rule of thumb is to never "idle" a lithium ion powered device on a low battery. Always charge it up good before putting it on the shelf.coline3bettson said:used TT ONE for a trip - worked perfectly.
Came home. Tiny town of 8,000 in NW Manitoba. Forgot about TT.
Recently, tried TT. Dead as a nit.
Plugged it in to Mac. Waited for battery to charge.
Plugged it into car lighter. Waited for battery to charge.
No luck in either spot.
Short story:
how do I charge the battery ?
paix,
Mrs. Bettson
