A lot of folks are finding that the line out level from the TomTom at its current firmware level is too high and is overdriving their aux-in port or FM modulator, causing clipping/distortion. Since that level cannot be adjusted on the TomTom, turning down the radio volume just reduces the volume of the clipped and distorted sound. The current firmware causes this same "no adjust" problem for directional information on the line-out output.Line out to the radio? Use the volume on the radio.
I'm holding off on 8.350 until I have some assurance that TripMaster will work. You wouldn't believe the number of aborted attempts I've had with TripMaster while TT keeps screwing with things and breaking it. I'd still prefer that they return to the adjustable output.Did you try app 8.350? It is supposed to lower the fixed line out volume to the point where it doesn't distort in most devices.
