The route I just created on plan.tomtom will not sync with the device. All the accounts match and to test sync works I created a Place on the web, and it appears on device and vice versa. What has not synced is a saved route even though sync is turned on, I manually pressed sync, the pop-up says synched, yet nothing.
I have reset the device and installed the updates. Any advice much appreciated.
