I just bought my Tomtom today, an XL
When I want to browse the map, the manual says "You can move the map by touching the screen and moving your fingers accross the screen"
This movement is very disappointing, to say the least!
I move my finger in a swiping movement up or down, left or right, diagonally etc.
The map moves, but not always, often the "Find" button moves instead (the little circle with the cross).
Sometimes the map just disappears and it goes back to the menu
I have tried moving my finger slower, longer, not near the Find button, not diagonally, tap then move, move all the way to the edges, etc but I still have trouble.
(Yes, I did peel off the protective plastic from the screen, and there is nothing wrong with my fingers)
Is there a trick how to move the map up/down & left/right with minimum hassle ? Or do I have to accept this as a badly designed interface?
Much appreciated
Much appreciated
