battery wont charge
Hello my 720 shows the yellow screen- that the battery needs charging and then switches off.
I checked that I am getting voltage into the device.
Maybe a problem with the socket? Does the battery need replacing? Do they fail such that the device just wont switch on. I thought that if it was getting voltage then the battery would be irrelevant?
Maybe contact Tom Tom UK ?
Ed
aestheheti
