Battery light
Hi,
I was just wondering, how long it will take to charge the battery? Manual says 2h. My 720 is on a cradle since about 4h and the green light is still on. I used TThome to log into 720 and then to check the battery status. When i tap on the bottom right corner is showing a gps satellites and battery sign, which is still charging mode. Is that ok?
thx
I think the light stays on all the time when it is connected to a power source. After 4 hours it should be fully charged.
The light stays on as long as there's power to the device. The meter shows charging as well, even though it may be fully charged.
How long does it last to play the mp3 songs via my car audio after a full recharge? It only last 30 mins for me, wonder is it normal or I have a defected battery?
Completely normal. You have to remember that the #1 battery drainer is the GPS Signal aquisition.
