Hi,
I have TomTom XL-S and I'm happy owner.
Though, the battery life is shortened to 30 min. Most of the time I have to keep it powered from my car. How can I replace the bad battery with new one?
Thanks,
Afan
The batteries are generally not replaceable, though if you've owned your unit less than a year they'll replace it for you at the factory. My battery (GO 920T) is down to about 5-10 minutes.
