Antenna location for xxl 540s
New York
XXL 540TM WTE
Please advise me where the antenna is located in a TomTom XXL 540S.
I heard it might be part of the car charger??
Thanks! :D
I wasn't talking about the antenna for traffic, but thanks for explaining where the traffic antenna for traffic is! :)
I was asking about where the basic antenna for the GPS functions was. Do you know?
It's a gps chip built into the device, not an antenna, that gets the gps signal from the satellites.
The antenna will be a light brown ceramic square affixed in a perpendicular fashion to the top/north side of the logic board. It has leads which solder into the logic board. These can be replaced. Here's a picture of what it typically will look like. Not all look the same but they are of similar size and hue, some are a darker brown and some are more cream colored. It is visible in this photo.
http://img191.imageshack.us/img191/4731/70291087.jpg
Presumably then it's NOT the item in the blue square in that pic? :)
That is pointing to the speaker plug. Just the best pic I could find.
Peter2471
