Adjust volume of incar TT on Renault Magan
Essex
How do I adjust the volume on the built in TT Device. On my 930 you just touch the screen, the volume control on the car does not reduce the TT vol. Help
Have you set the speakers to use FM? If so, are you saying that turning the volume knob on the car radio (while on) is not reducing the volume through the speakers?
That should be the (only) way to do it...
The manual says
Volume
Changing the volume
To change the volume, use the audio
system volume control during a voice
instruction. If the instruction is too quick,
you can repeat it using the “REPEAT/
MUTE" button on your central control
unit, or use the left soft button on your
remote control.
Refer to your audio system’s handbook.
