920T and LG phones
Ewing NJ
920T
Anyone know if the LG Shine is compatible with the 920T?
Also anyone know if Sony Ericsson W580i is compatible?
I've got a RazrV3 that works with the 920T somewhat..but I'm upgrading my phone. My carrier is AT&T and I want to make sure I get something that will work with the 920T. Thanks
I just got my 920 a couple of days ago and it was very easy to get it connected to my w580i.
It works flawlessly and the sound quality is well beyond what I was expecting.
Thank you very much..I am definitely leaning towards the W580i. I called TomTom and they are saying its not supported..but if it connected fine for you and the data transmission works fine then I'll probably get it. :)
I've got an LG CU500. The hands free calling works fine, but the rest of the features (text messaging, data services, phonebook, etc...) don't work with the 920.
The Shine might work fine though.
LG 8700 Shine
Hello, I have a LG8700 Shine and a GO920. For hand free call, no problem, but is the only you can do.
BLARGHBLARGH
