I HAVE THE 920T AND JUST INSTALLED THE 8.350 APPLICATION. UNFORTUNATLY i FOUND 2 PROBLEMS. AS EVERYONE KNOWS THAT WHEN TRAVELING FROM POINT A TO B THE RECEPTION ON YOUR RADIO CHANGES ACORDING TO THE DISTANCE FROM THE TRANSMITTER. SINCE NOW WHEN USING THE RADIO FM TRANSMISSION FOR DIRECTIONS, THE DIRECTIONS THAT TOM TOM GIVES VIA THE RADIO CUT OUT WAY TO SOON AND THE VOICE GOES BACK THE THE TOM TOM UNIT SPEAKERS AS THE SOUND LEVELS CHANGE IN THE RADIO. THE SPEECH RETURNS TO THE TOM TOM UNIT WAY TOO SOON AND THE LEVEL OF MUSIC IN YOUR RADIO BEGINS TO CUT OUT. TOM TOM REALLY HAS TO EVALUATE THIS TYPE OF RADIO TRANSMISSION. iT REMINDED ME OF THE 910 UNIT WITH THEIR DOCKING STATION IN THE AUTO WHEN IT HIT A BUMP THE FM TRASMISSION WOULD CUT OUT ALSO
SECONDLY THE LOUDNESS OF SPEECH IN MY 920 BEFORE THE 8.350 UPDATE I WAS USING 90% OF THE MAXIMUM SOUND OUTPUT. AFTER THE NEW DOWNLOAD THE SOUND IS NOT AS LOUD AND I HAD TO RAISE THE LEVEL OF OUTPUT TO 100% AND EVEN AT THIS LEVEL IT IS SLIGHTLY LOWER IN SOUND THEN MY ORIGINAL 90% I THINK THEY CHANGED THE SOUND LEVEL BECAUSE SOME PEOPLE WERE COMPLAINING THAT WHEN TALKING LOUNDLY SOME OF THE SPEECH WAS DISTORTED. AGAIN TOM TOM SHOULD HAVE DONE BETTER RESEARCH AS TO THE PROPER LEVEL OF MAXIMUN SOUND. MY ONLY COMMENT IS THAT THEIR MUST BE SOME BETA TESTING IMPROVEMENTS BEFORE RELEASE. IT IS MY OPINION THAT ITS BETER TO TAKE A LITTLE MORE TIME IN THE IMPROVEMENTS THEN RELEASING VERSIONS NOT PROPERLY TESTED. NOW THEIR WILL BE COMPLAINTS AGAIN THAT SHOULD NOT BE.
