340TM code activation problem
I had a problem with my TomTom map update which I have mentioned HERE
Now I have another problem..I am trying to activate the code for lifetime maps and traffic..but I am getting an error..
ERROR: 537/#https://community.tomtom.com/shop/activatePromotion: Error from server: XML is not valid
XML is not valid
Error code: 537
URL: https://community.tomtom.com/shop/activatePromotion
Additional information: info = [object]
info.func = [string] shop/activatePromotion
info.args = [object]
info.args.promotionCode = [string] my activation code
info.args.deviceSerial = [string] RU4430I09236
info.method = [string] GET
info.useCache = [string] true
info.dryRun = [string] false
info.xmluploadbody = [object] empty
Severity: 1105
Stack:
0. chrome://tthome/content/logic/comm.js:468
xmluploadbody: this.xmluploadbody
1. chrome://tthome/content/logic/comm.js:430
this._doneCallbacks();
2. chrome://tthome/content/logic/comm.js:277
this.request.onload = function() { me._done(true); }
In short it is showing that the code is correct but it is having a problem while contacting the server..XML IS NOT VALID..
Please help me guys:(
How to actually fix the problem
As I said in other thread, call CS.
You seem to be missing the point of forums, they are so that you don't have to call support. Especially for people like me who got a TomTom for their parents and wanted to set it up before giving it to them instead of fielding 50 phone calls when setting it up.
I found the fix in an Amazon review. Basically, delete the map off your device and off of your computer (located in your documents), reboot your computer and reconnect your device. Once it sees the device click "Update". It will notice there are no local copies and will re-download the latest maps pack.
I suppose just telling people to call Customer Support is easier than giving them a solution. Oh wait, they're closed the day before Christmas this year so I could have either given them a broken device or researched a solution. How did you get to be a "super moderator" again?
