2 map correction function was removed from 720
wjm
Vancouver
Go 730
from Tomtom online help, "What sort of map corrections can I make with Map Share?? " the turn and speed correction function only for Go X30, But I can do it before on Go 720 with map V710.XXXX, after update to V815. I can do correcting but it not working when calculating.
there is a 'no left turn' error on tomrom map (also google map), I go there everyday, Google satellite picture show:
http://maps.google.com/maps?f=q&hl=...77,-123.031554&spn=0.000188,0.000962&t=h&z=20
I reported it last year, but it was not corrected on the followed 3 version, when I buy GO 720 w/ map v710.XXX last week, I can correct it myself, but after I upgrade map to 815.2019, the error still there, but I can't correct it.
don't know it is permanent or can be open to X20 device someday.
from Tomtom online help, "What sort of map corrections can I make with Map Share™? " the turn and speed correction function only for Go X30, But I can do it before on Go 720 with map V710.XXXX, after update to V815. I can do correcting but it not working when calculating.
What navcore application number are you using (ie. - 8.001 or 8.3) ?
PS - I am on 8.3 with 810 maps - all the Map Correction functions work on my 920.
