- Joined
- Aug 19, 2017
- Messages
- 2
- Country
- TomTom Model(s)
- 1615TM
I have too many devices in my car not enough outlets so I decided to run a direct connection from the fuse block to the TomTom. I purchased a 12v-5v block and ran a fuse tap from the block. I thought I verified the power lines from the TomTom cable having read that there was a sensor line and a 5v ground. I matched the lines and thought it was working well until last night when I fine that the TomTom is not charging. I went back and verified that the block is giving me 5v and then looked at the sensor line only to find that a the splice point that I left hanging is actually another coax wire with ground and power leads, I think, and I have no idea what I'm going to do with those. Do they also connect to my 5v block or direct to 12v or ???????. Any help would be appreciated.
Thanks Friggin New Guy
